2L Kombi Auto Problem diagnose please
kombikim - February 25th, 2005 at 10:52 PM
I have just bought a 2L Auto Kombi
unfortunately the transmission is better than perfect in forward gears BUT reverse has a bad judder , even under light throtle
also weird is if you hold you foot hard on the brake & rev motor
nothing happens (correct) but engine shakes & clatters i& there is a judder if you do the same in reverse. al four of my manuals do not of course mention this symptom in their diagnosis charts
seagull - February 26th, 2005 at 12:54 AM
You may find the motor mounts ( or ) the front mount on the trans is busted .
have a good look .
The 2ltr auto is very > very good , but get the auto serviced and clean the strainer out .
kombikim - February 26th, 2005 at 10:24 AM
found it ! engine was running very rough when I bought it yesterday, valve clearences closed, on 2 cylinders fixed that this morning & everything is sweet as
motor shaking pulled & realeased on accelararior causing the judder, mounts a re probably a bit zorked too
I a happy guy now
Andy - February 27th, 2005 at 03:38 PM
Cool dude!!
So you will have Kombi twins soon :D
kombikim - February 27th, 2005 at 06:31 PM
Have Kombi twins now , Jenny likes it & wants to keep it
State Govt will be happy with my 5 full rego's
Andy - February 28th, 2005 at 07:40 AM
Ouch!! :D
