input shaft sleeve
oval TOFU - February 28th, 2005 at 02:43 PM
Will this get in the way of fitting a 40hp 1200 engine? I've had a 1500 gearbox installed...
oval TOFU - February 28th, 2005 at 02:44 PM
from below...
Menangler - February 28th, 2005 at 02:57 PM
You will just have to take the ring off the pressure plate, that is the later style clutch throw out, the other problem you might have is the 6 volt starter won't bolt up to that gearbox with out an adapter bush.
oval TOFU - March 1st, 2005 at 06:08 PM
The ring? Is that the part that the throw out bearing presses up against?
Menangler - March 1st, 2005 at 08:57 PM
Yes
oval TOFU - March 3rd, 2005 at 12:02 PM
forgive my ignorance, but if you take off the ring that the throw out bearing pushes up agianst, how will the clutch work? what will the throw out bearing push up against when you push in the clutch pedal?
vw54 - March 3rd, 2005 at 12:33 PM
if you have a 3 fingered pressure plate then it wont,.... if you have a diaphragm style pressure plate then it will be OK.
Menangler - March 3rd, 2005 at 07:30 PM
Yes it will work with both types of pressure plate
oval TOFU - March 4th, 2005 at 11:08 AM
cool! ...so I just yank it off with my hands? I just dont wanna distort the diaphram fingers.. =)
oval TOFU - March 5th, 2005 at 03:43 PM
done it!
