Being the optimist that I am, I'm hoping to finally get my Kadrons running tonight after 4 days of grief. Only one question remains. The manifolds have a fitting just below the plate where the carbs attach which seems to go straight through to the inside. What are these meant to connect to?
I have a balance tube between them. I'm not truly sure it does anything at all, but its far too big to be a vacuum port.
Suprised to hear you have had problems with the kadrons - mine came off of a car that hadnt been driven for 3 years and were covered in oil and
crap.
A can of degreaser and a can of carby cleaner later, they worked a treat first time.
You will enjoy them once you have the engine running with them
balance tube to equalise the carbies...........using a piece of fuel rated hose connect both the manifolds together, with the tube running behind the
fan housing.
THIS MUST BE CONNECTED.
yeah twin carbies! :thumb
you'll need twin fuel tanks now too
