well I pulled out the starter 2 c if it is stuffed as she would not turn over & was making that loud noise(vibration)~
I removed the end part off the starter & was greeted with a hell of a lot of loose carbon is this normal~ the teeth r fine~ r there obvious signs?
what di I look 4? THANKS
Sime~
Start looking for an Auto Electrician !!!
SO~ the carbon means its stuffed?? & that is my problem??
thanks
Sime~
