Running on 3 when cold?
chickenfillet - March 14th, 2005 at 07:51 PM
Hi Guys,
My '68 sounds like it's running on 3 cylinders when it first starts and for about a minute after, then after it warms up it seems to run fine.
It had new plugs, points, plugs etc about 2000 miles ago.
Any ideas?
vw54 - March 15th, 2005 at 07:58 AM
Check or replace the dissy cap and rotor button.
Jeza - March 15th, 2005 at 08:07 AM
Is it running too rich at idle?
When its hot it may cope with it, but when its cold it just fouls the plugs (one plug)? Over choked?
I don't actually know this is just a guess.
Also check the leads, 1 lead may be on its way out.
Jeremy
Chewy - March 15th, 2005 at 10:25 AM
Could be carb iceing??
chickenfillet - March 15th, 2005 at 10:39 AM
Thanks for the reply guys, found a small crack in the dizzy cap. Fix it on the weekend.
Thanks again,
Kev
