The manual (1979 Kombi) I have says when removing the gear box remove the engine and gearbox as one unit.
As I am doing this on my own, I would have thought to remove the engine first just from a weight point of view.
Which is easier?
If you have a decent sized floorjack and enough flat concrete then it is easy enough to do by yourself....just make sure you put the jack under the
engine but close to the gearbox end to balance the weight.
Graham
Gday Graham,
Regarding the 1600 Kombi gear box you have in your bus, does it go in place of the 2 ltr box with out any modifications to the mounts or gear change
linkages?
My Kombi was auto when I got it, and I'm not sure what parts I used when I converted it to Manual, but I have changed from a 1600 Box in 72TWINCAB's to a 2L and we had to shorten the gearshift linkage, so I'd guess if you went from 2L to 1600 you'd probably have to lengthen the gearshift linkage about 20-30mm. The mounts should line right up.
