Wondering how good the fuel injection was on the tle. The daughters fasty has had carbs put on. Wondering about changing it back. Anybody have any thoughts?
Dont really know but mine is running unchanged not missing a beat now with over 300k km's.
From what I have seen its pretty good - this assumes that everything is in working order as fault finding can be a problem unless you are experienced
at fault finding EFI stuff..... of course there is only one way to be experienced!
R
Hey there,
I just did the conversion back 2 efi, and wouldn't go back!!!!
You wil notice the acceleration boost, just make sure the system is working properly and the wiring harness is in reasonable condition and find some
new pump rubber mounts, i almost discovered the consequences, I found it dangling from the fuel lines!!!!!!!!!
Kieran
