Fly Wheel
jaksc - May 2nd, 2005 at 09:15 PM
How do you tell the difference between a 6 volt and a 12 volt flywheel?
VolksFolks - May 2nd, 2005 at 09:20 PM
teeth count and spacing, clutch is smaller, i canna remember the actual tooth count sorry, sure somone will know!
Grey 57 - May 2nd, 2005 at 09:26 PM
6 volt flywheels (not type 3 ones) generally use a 180mm clutch assy. 12 volt have a 200mm clutch assy. Measure across the area where the clutch pressure plate fits in. If its a little over 180mm its a 6 volt. If its a lot over (like more than 200mm its a 12volt. Unless its a Type 3 6volt flywheel. Confused yet?
Craig Paton - May 2nd, 2005 at 09:43 PM
119 teeth - 10 3/4 inch dia
130 " - 10 7/8 inch dia
I'm pretty sure that the 6v is the 10 3/4 inch dia.
phatrat - May 2nd, 2005 at 09:54 PM
another way....starter motors are totally different...
karmen - May 2nd, 2005 at 10:06 PM
how disgusting!!!! inches for Metric cars phew!!
jaksc - May 3rd, 2005 at 06:09 AM
I have 2 flywheels that have 200mm clutches but are different sizes. Trying to work out which is best to use so i can get it balanced. The one that came off the car doesn,t look like it was meshing proply with the starter as the teeth are slightly worn one side where as the other one is perfect.
vw54 - May 3rd, 2005 at 07:22 AM
Go and see Pete Korsche at Gosford.
