1600 twin port > head depth question
seagull - May 22nd, 2005 at 12:36 AM
I have a 1600 twin port that has had the heads machined , can some one please tell me .At what depth of a stock head you need to fit copper head spacers .
The measurement of depth of a stock head is ?
cheers seagull
toplessbug - May 22nd, 2005 at 06:31 PM
mine measure 12mm from the flat to the seat ,stock
jakjones - May 22nd, 2005 at 08:18 PM
there not all the same but u can go to about 14mm before u run into clearance issues with the top fin.
Top fin can be skimmed to clear or a spacer ring can be used,
compression ratio now thats another issue to think about.
Bizarre - May 22nd, 2005 at 09:25 PM
as jj said.
The more you cut you then need to "cc" the heads.
Can get tricky once you have taken away all the easy bits of the head and opend them up.
"most" heads seem to be round the 50cc mark - but you can get them to work either side of this.
seagull - May 22nd, 2005 at 10:24 PM
I am thinking of valve clearance & valve adjustment as well
