Hi,
I'm looking for the specs on late (IRS) Type 3's.
I'd like to know the Track for both Front and Rear, and the Widest manufacturers optional tyres.
I have a type 3 I am looking at putting some after-market wheels/tyres on. According to QLD Mod rules I can only change the track by 26 mm and tyres
can only be 1.3 times the width of the manufaturers widest tyre.
So I need to know the stock track, and widest optional tyres.
For completeness, if you have the specs for both early and late Type 3's feel free to post all info.
Front track=51.6" (1310mm)
Rear track=53" (1346.2mm) or 53.14" (1349.8mm) for TL models
Production tyres were 6.00-15L4PR cross plys. The only tyre option listed is a 165SR15 radial ply. Therefore the widest you can legally go is
214.5mm. One of my fastys has 205s on the back, and they look pretty fat IMHO. I don't think you could fit much fatter without scraping the whels
arches.
Wheels are a 4.5J x 15 wheel with 46mm offset.
This is from the Bentley manual for 68-73, Grgory for 63-73 and a 72 Owner's Manual. There are no different figures quoted for earlier models except
for the minute difference in rear track width for TL models.
I thought Qld used the same rules as NSW, pre 73 it goes on the final weight of the car
Up to 800kg 153mm (6 inches)
801 - 1000 kg 178mm (7 inches)
1001 - 1200 kg 204mm (8 inches)
1201 - 1400 kg 229mm (9 inches)
1401 & over kg 254mm (10 inches)
After 73 it gets tougher.
I found same info as PurpleT3
Some additional interesting bits:
type 3
rear:
torsion bar length 24.6"
torsion bar dia 0.91", 0.94" (depends on model)
Wheel base 94.5"
length 13' 10.3"
height 4' 10.1"
width 5' 3.2"
turn circle 36.5'
tank 8.8 imp.gal.
rims 4.55 x 15 (4.5J15)
tyre size 5.6x15
type 3 1600TL
torsion bar length 26.6"
torsion bar dia 0.866"
tyre size listed as - 590x15??? 4 ply or 6 ply depending on model.
tyre size seems different to what purple found though.
0-80mph in 40 sec
