What is the size of the driver needed to take out the socket head screws on the cvs on a bay window bus? I need to get one as none of my allen keys
fit.
Nicko
8 mm from memory
here may givr you some idea
http://www.aussiekombicampers.com/index.shtml
Andy
They are a star spline arent they???
They are slightly bigger than 6mm but slightly smaller than a 1/4 allen key. Hoping to get an exact size so I can get a tool shop to order on in. I
dont think they will have to match as a sample. Couldnt find it on the camper site but it is a nice looking site
Nicko
i have them for $8 each
Thanks guys I will check tonight to see what they are. Looked like allen keys but I didnt clean them real well so they cound the double hex type.
Nicko
mine id def a allen key, probably changed at some point
hey nicko
clean them really well or you will be under there with a chisel and a hammer to try and release them!! they will be 6mm hex like already stated or
that spline tool!
CLEAN THEM REALLY WELL!
rhys
I second what Rhys said, and add that it's worth applying your favourite penetrating oil the night before you have a go at them.
The ones on our bus are 12 spline also
mine are allen key, found that one per wheel seems to have a slightly larger hole in it, also found that good quality allen keys will fit even if cheapo's feel loose
get the allen key hat will go onto your 1/2" drive socket!! even better me reckons!
you cn never have enough penetrating oil i sometimes drink it if my bones are aching!! frees them up straight away!
rhys
get a good quality bit. Trust me. Sometimes you need a lot of force to undo them. And then there's doing up. For some reason mine always undo themselves...
When I took ours ou the other day, they had 12 spline on the gearbox end and hex on the wheel end. The 12 spline I tapped the spline bit in with a
hammer, and used a 8mm spanner to 'crack' the bolt. They are very tight and it is the tension of the torque they are done up to that makes them hard
to undo.
They also had small serrated washers under the heads to stop them coming loose.
Kombi used 6mm single hex, Beetles & Type 3s used 6mm double hex, I always scratch the hole out with a screwdriver, then give 1/2 drive tool a tap
with a hammer to make sure that its seated properly.
I'll check that when I pull out the battery. Should be able to see them without cracking the bolts off.
I thought they were 8mm multihex for the bolts. I don't remember anymore. Just about every VW I have worked on is an oddbod.
