Hi all,
I currently have a 1970 Type 3 Notch and have been playing around with some ideas , so it has a so called "different look."
I recently bought some early bullet style indicators from Dannyboy67 and was just about to throw the ugly 1970's versions away as far as possible
when that little voice in the head said stop.
So the question is for all those electrical people out there.....
Will there be a problem with the indicator since it is only 6v. Do it need a special thingy in the indicating wiring loom to convert 12v to 6v? Or
just a different globe?
Many thanks in advance.
Cheers,
Brad
should just need to replace the globe
the only thing that makes it 6 or 12volt is the globe you use.
Thanks akean1 and blutopless2 for the info.
Cheers,
Brad.
