hi there
my swing axle bug has been slammed at the rear and now started to make a whirring sound from the rear wheels u can hear particularly when slowing
down, but not from braking. could this be that no oil is getting to the rear wheel bearings coz of massive negative camber? i jacked up the back for
an hour b4 driving today and the sound didnt seem to b there for a while but returned.
is there some way to get around this like sealed bearings?
wat damage am i doing if any?
help is much appreciated
sam
i also have a strange sort of light grinding sound coming from the rear passenger side. i dont like it![]()
bump an old thread coz i need to know too...
time to Un Slam
yes lack of OIL will cause this problem
Jack it up and spin the wheel does it still make the noise ???
just replace the wheel bearing with a sealed unit.
my problem is solved long ago, just loose bolt on the spring plate allowing a bit of movement
mine is/was rubbing on the inside of the right rear wheel....some bit sticking out of the car is rubbing lightly on it...and when i have adults in the back, it rubs loudly.....but when its just the kids, it barely rubs at all.
fixed mine too......i like a happy ending
