..will I need to take my head off? ie: engine out?
sounds intereting... I'll investigate...I'm not too keen on getting my engine out again...
yes - no - ish
You "CAN" use screw in replace ment tubes.
DO NOT USE THE SPRING LOADED TUBES. THEY ARE CRAP.
They are about $25 each but yes it saves pulling the motor and taking the head off.
Just make sure everything is clean clean clean
i'd rather spend the $ than take my motor out - it's a real tight fit in my oval for some reason... where do ya think I can get em Bizarre?
most VW shops.
I puleed a motor once and some goose had used 8 of the screw in types :jesus
VVDS sells them but depends on what they can get their hands on - some times screw - in some times spring in
maybe check Mick as well. Volkspower??
