replacing needle bearings in front beam
sean68 - July 27th, 2005 at 08:40 PM
Is it a good idea to replace the needle bearings in my ball joint front beam with the bugpack urethane ones
Adam_C - July 28th, 2005 at 12:32 AM
unless they are shagged why bother?
Che Castro - July 28th, 2005 at 10:17 AM
I just repacked mine with grease. Apparently replacement bearings are a bit difficult to track down, but I'd suspect that needle bearings would be smoother and work better than urethane.
sean68 - July 28th, 2005 at 06:56 PM
yea i was told not to bother putting the urethane ones in if the bearings were ok
just wanted a few other opinions
