does anyone happen to know what the ground clearance of a standard beetle is and where it is measured from. gotta raise mine and wanna know how high
to go and where i measure it from.
Thanks.
P.S
Don't panic people it will be lowered again later.. :thumb
In QLD the lowest part of the car must be at least 100mm from the ground whether that be body work or exhust etc.
Marc
what he said its australia wide as its in the adrs. from lowest point to the ground
Just to add to this....10cm off the ground is the minimum, but also the middle most point of the headlights must be greater than 59cm.
i heard the exhaust doesnt count, is that tru, in NSW?
nope to the lowest point be it the exhaust or body
The only bit that doesn't count is brakes.
59cm to the headlight?
There are a lot of new cars that can't pass this
I have heard it must be the lowest point of the car where it's measured from, and 100mm off the ground. Some people say it's the size of a coke can.
Ooops... I don't think a coke can can fit under my car! LOL
thanks everyone.
At least i now have something to aim for with the height.
