For the first time in it's whole life, our elderly swift has broken down. I traced it to a broken fuel pump. This was ok until I had to replace it
which involved dropping the whole tank...which was half full. Took me 3 goes to find the right pump and now it will not pump properly. I assume the
system should be self purging but it is not. The pump is running fine from what I can hear, but there is no petrol reaching the filter which is right
next to the tank, or the carby.
Any ideas?
I have to get it fixed tonight so the boss (wife) can drive it tomorrow.
And yes the tank has plenty of fuel in it.
do you need to prime it some how??
don't know, sucked the fuel through the line in two places :puke
but it didn't seem to help. I have to say, even the buggy is easier to work on.
Is the fuel filter blocked?
nope, there is plenty of fuel flow when I suck on the fuel hose in the engine bay. It seems like the pump is not pumping the fuel up out of the tank. Stuffed if I know why. The tank is half full and the pump should be pulling it up into the line no probs.
you do have it connected the right way round???
The + - connections right?
Doesn't look like it. Managed to get the old pump to run for a second. Seems like it only runs in one direction. The other direction. Oh another fun day tomorrow. I get to drop the tank for the second time and pull the whole pump assembly out again.
Nasty pump manufacturers had a black wire for the active and a red wire for the earth!!!:cussing
Damn I hate working on new cars!
Now the clutch is starting to slip!!!!!
lol... buy a VW!
Try here next time...
http://www.mywifessuzukiaintworkingandifIdontfixitshellkickmyaskforum.com.au
:P:P
The Suzi's are a tough little car - as you say, nothing special but they just go and go and go.... not enough power to hurt themselves.
The company I work for runs 80 (no thats not a misprint) of them as delivery vehicles - so imagine the hardest you have ever driven your car, then
thats about the easiest that our swifts ever get driven. The only regular problems so far have been the drivers side window reg failing and the
gearboxes only last about 2 years (18 year olds attempting clutchless gearchanges make sure of that!
Hope you sort out the problem with yours ASAP.
R
