Hi,
Another chapter in the saga of my kombi. When dad was driving it to get it registered, he sed it started smoking, and smoke was coming out of the
dash!!!!!!
What's going on???
Also, my engine appears to have some home-mechanics work done. It was two cans, that look like they're covering something. Will take photos sometime
soon so you can see.
Any suggestions/solutions?nn[ Edited on 10/9/2005 by jimmy ]
smokin hey, could have some wiring shorting out and that may lead to a fire and no more bus.. CHECK IT OUT man
+ get yourself a fire putteroutera device that stop flames.. you know the thingo.. always safer to have one in a VW..
cheers paul
If the smoke was coming from the dash and the engine it could be an oil leak onto the heater boxes. Then as the boxes heat up the oil smokes like
anything! I had a leaky push rod tube and it caused some bad smoking but was easy to fix. Worth checking out anyway.
Cheers,
Dustin
thanks guys, thats been helpful. I plan to take her for the full hard on detailed service on mon. So hopefully that will work, but I was hoping it
wouldn't be anything too bad.
Cheers, and as always keep helping me out.
You can see photos of the engine etc. at
http://photobucket.com/albums/v654/fury_jazza/The%20Kombi%20Archive/
Jim
It wooks like they have put cans over the tubes that go down to the heater boxers. Where the cans are the tubes from the heater fan fit to blow air
over the heater boxes the in to the cabin. I have welch plug blocking mine.
Marc
I kinda deduced that. But thanks for all the help guys, and I am still happy for any other suggestions.
