76 AUTO Kombi the best and the worst
kittendeluxe - October 12th, 2005 at 12:16 PM
Hey all.
Looking for hints and tips on where to start, what to look out for and what to avoid when making my kombi as safe as possible.
At the moment she is registered as a two seater, - despite having a two seater in the back which folds out into a bed. The previous owner failed to get modification plates - walk through, with westie windows.
Based in Cabarita just south of the tweed but am up in Brisbane 2 nights a week so any info from the qld or northern nsw kombi gurus would be great.
:sandrine
ned - October 12th, 2005 at 08:34 PM
hi kittendelux
this isn't really answering your questions, but i have a similar vehicle and this is where i am coming from .... i am definately NO mechanic as the most technologically advanced piece of toolery i own is a claw hammer and my mechanics phone number.
i have a 75 camper westfalia and my compliance plate also says or specifies that it is a two seater. However, when i bought her about 6 years ago, i became the third or fourth owner and somewhere along the line someone had also put in a fold out bed seat making her a four person vehicle. seat belts were attached before i bought and i have had no ttrouble registering the van ever since i have owned it.(i have never seen a moidification certificate either) Now living in nsw might have different laws to that of qld but thats how i've "lived" ie, it hasn't been an issue. As for safety, well i already had retractable seatbelts in and i only drive at 80kph to 90 kph. My mechanic is very thorough with it says that it is in very good shape.(I have tried to keep it stock standard) So i guess if it is in good nick mechanically and driven sensibly it should be ok. If i could, about the only thing on my wish list would be ABS brakes, but that is only piece of mind, then again if its driven sensibly....
all the best
ned
mnsKmobi - October 13th, 2005 at 03:11 PM
I've thought about this very question and come to the conclusion that the best you can do without ridiculously expensively rengineering your kombi is to make sure that the various basic systems that it came with from the factory are in good working order. i.e. brakes, steering, suspension, tyres, lights, etc. I suspect there is enough stuff that needs doing on these areas in many kombis on the road to keep the owners busy for some time. A good starting point is if it's rubber and original replace it! Suspect items include fuel, brake and vacuum hoses and the rubber disk at the base of the steering column.
bus914 - October 13th, 2005 at 07:23 PM
the 76 brakes are quite good when working properly
kittendeluxe - October 17th, 2005 at 05:34 PM
Cheers Ned,
It was good to hear that you've had your fold out certified. I will have to check out with the RTA exactly what the prob is, i think it may have to do with the seat back being held up by door bolts. Is this standard?
Since i have had her the few times i have gone over 80 kph the fan belt has slipped off, but i have had a new one with ridges put on and that seems to work a treat... ABS brakes certianly sounds brill...
Tah
em
kittendeluxe - October 17th, 2005 at 05:37 PM
hey all,
BIG THANKS for all the info I have taken the comment to have all the rubber replaced esp the fuel line. Have had my brakes overhauled and have had the play taken out of the steering wheel. I have also replaced the seal around the engine:no:
