wheel alignment
nuffy - November 2nd, 2005 at 12:49 PM
anyone know a place i cna get my 75 kombi a wheel alignment near browns plains or anywhere on the southside of brissie? i was under the impression normal places (eg: bob jane type places) arn't much good for old VW's???
BiX - November 2nd, 2005 at 01:02 PM
Try hank shcumaker steering and suspension on i think industry road. Knows old acrs, does a good job. I used to go to him but getting time off from work at toowong and getting to brownsplains and back is hard.
vw54 - November 3rd, 2005 at 07:55 AM
Have you trailing arm and steering rod Ball Joints tested and checked for wear before you spend the money on getting your wheel alignment
BiX - November 3rd, 2005 at 08:20 AM
Hank will normally tell you if they are worn send you away to get new ones, without charging. Hes normally pretty good.
vw54 - November 3rd, 2005 at 09:31 AM
yeah thats good if he does that but to change the trailing arm ball joints you have to remove the trailing arm and use a 25 ton press to push them out n re fit the new joints.
Midlife crisis - November 3rd, 2005 at 10:12 AM
Hi Nuffy
I just had one done on my Daughters Fastie at
Bridgestone Tyre Centre Geebung on the corner of Newman Rd & Prosperity Place. He has been doing VW's for years . We very happy with the job done it the best the fastie has driven for a long while, and they do it at a good price $39.90.
Marc
nuffy - November 3rd, 2005 at 12:30 PM
thanks for the replies people.trailling arms are fine as i just had the ball joints on passenger side replaced and had the drivers side given the OK. will check steering rod ball joint before hand. that place at geebung sounds good also. thanks alot.
