What is the bore size for the single circuit ('68) beetle master cylinder?
Did the L bugs have a twin circuit master cylinder?
Anything that bolts straight in more or less?
17mm I think.
Later (when?) went to 19mm.
L bug has an angled bolt pattern.
Will fit with some work...don't forget the spacers in the bulkhead!
[ Edited on 13-11-2005 by dangerous ]
The single curcuit only came on the drum brake model 67 or earlier, it was 19 or 17mm. The dual curcuit ones were all 19 mm.
hmmm looks like they kept the drum master cylinder when they turned it into a buggy then...
thanks guys will grab a new dual circuit one then.
