hey peoples
is it dangerous to drive without a front sway bar?? i need to get a different sway bar for my lowered bus so am without for a little while?
rhys
Not really.
Just expect more-than-normal body roll. It won't handle as well, so you just need to adjust your driving style to compensate.
Wet up your way Rhys, or are you working in the shed?
ok kool there will be limited suspension movement anyways it will be that low ahahahahaa yer pissing down rain so just put some new pads in the front
discs and put a new master cylinder on broke the bloody break fluid tank that sits on top of the master cylinder but so am trying to hunt one down!
rhys
