Type3 auto wiring diagram
Tazzielittle - March 24th, 2003 at 02:06 PM
Does anyone have a diagram showing the Auto type3's?
The wires from kickdown and to the carbs?
Someone has played with the wiring and I would like to put it back to standard.
cheers.
aussiebug - March 24th, 2003 at 02:28 PM
You can find most wiring diagrams at http://www.vintagebus.com
They are mostly US VW diagrams and their VWs sometimes had extra items like rear window demisters, but they are still useful.
I think Dave Hall's type3 site has some as well. He's at http://www.hallvw.clara.co.uk
vw54 - March 24th, 2003 at 04:55 PM
Whats the problem Tazz??? the power for switch comes off the pos side of coil and the other side of switch goes to the solinoid on the box
Tazzielittle - March 24th, 2003 at 08:06 PM
But dave,
There are terminals on the throttle link at the cable. 2 of, and one is hooked up and one is not...
Someone has put a heap af piggybacks on the coil and it looks like a daisy chain at mardi gras!
Thanks aussiebug, I'll have a lookie!
Tazzielittle - March 24th, 2003 at 09:35 PM
Tis ok...
I have forund one in a book that was givin to me that I hadn't looked at yet...
vw54 - March 25th, 2003 at 06:33 AM
Tazz yeah thats Ok the switch on the accel linkage has 2 terminals.. one to power on coil n the other 2 the gearbox solinoid...
Ring me if yr not sure 02-8304-4109.
yes there should be some piggy backs on the coil... the + side also has reversing light output and another wire for auto choke and air idle solinoids.
Tazzielittle - March 25th, 2003 at 01:48 PM
Thanks dave!
