HELP! flat spot on take off, daily driver
kroozzn63 - December 8th, 2005 at 10:33 AM
my ute has a flat spot on take off and when i put my foot down it splutters then takes off.
only when i accellerate it spultters if its a bit hard on the pedal otherwise ok but i drive it all day every day i need help so i can feel ok driving home today "NOTE" i have pulled out the idle jet and theres no gunk in there
jo_tas - December 8th, 2005 at 11:02 AM
From experience fixing stuff on my type 3... check the fuel pump on the carbie(s) and your vacuum advance, if you have one.
kroozzn63 - December 8th, 2005 at 12:23 PM
thanks check it does that mean tap it with a shifter?
Bizarre - December 8th, 2005 at 12:26 PM
Is this something new or always there??
What is the motor / carb / dizzy types???
PrettyBlueBug - December 8th, 2005 at 01:58 PM
My Bug was doing this, and it was the points.... are yours all good?
jo_tas - December 8th, 2005 at 09:23 PM
Sorry i meant accelerator pump... i had the same problem with my car and it turned out to be that the accelerator pump wasn't pumping in enough fuel...
64vwmark - December 8th, 2005 at 09:27 PM
Had a similar problem recently, it turned out to be a vacuum leak.
crewcabconnection - December 8th, 2005 at 09:37 PM
Bendon...Kimm at Indian has flat spot remover. He's called Damien.
