type 3 tail light question
Stanley - February 21st, 2006 at 08:13 PM
Can anyone tell me the correct tail lights for a '69 notch thats the old shape. Has the skinny wrap around front blinkers.
are they the flat ones or the deeper ones?
Kombi_Rescue - February 21st, 2006 at 08:18 PM
the factory changed the fklat lens lights in 1965 ,so 64 and easrlier only used the flat ones..cheers steve
Stanley - February 21st, 2006 at 08:25 PM
buggar....thanks Steve.
I thought that might br the case...I found a notch manual on the weekend at the swap and it basically said the same.
Now to find some different lenses.
bitemeoz - February 21st, 2006 at 08:45 PM
like this
1500S - February 21st, 2006 at 08:45 PM
The first larger ones were first seen in 1963 (1964 model) with the introduction of the 1500S. Should be plenty around as they were standard on all fastbacks from 1966 as well as notches and wagons.
1500S - February 21st, 2006 at 08:47 PM
Bitemeoz! How did you get on with the popouts! Was that your post?
[ Edited on 21/2/2006 by 1500S ]
Stanley - February 22nd, 2006 at 06:53 AM
Anyone got some larger lenses.....i've got two pairs of the narrow ones....
davidmaleny - February 22nd, 2006 at 01:06 PM
Hi, saw your car at dubs@pubs, nice, tried to spot you but missed you - was trying to workout date your car - lenses and some parts were older, dash was '69. I have some parts for notchies I'll have a look - prob. with lenses is they go to buggery in Qld sun. Bought my last ones from volksfolk Tassy. Also Melb.guy on ebay has them a bit - bouncerandboo - check it out. If I spy any I'll email you. David
DallanMulley - February 22nd, 2006 at 03:50 PM
Hi swap yours for mine John
