:sandrine
Would someone know if a '73 beetle dashboard fit straight in to a '75 model ?
Want to replace put don't know weather it would fit correctly.
Anyone done this?
Judy
if we are talking 73L to 75L then no problems
just time and effort
hey judy
yeah there the same
pita job though
there was a flippy blue 73 Lbug just down the road from u in a shed for ages that had an electrical fire under the dash i was gonna buy it but couldnt
find another dash for it
Joel
from memory 73 has some slight differences from the 74, 75. Mostly vent stuff. It will work but there may be a few things that need adapting.
Gloveboxes lids and latches are different and not interchangeable
i have had 2 x 74 and a 75
my mate has a 73
yes the glove box is different but that is all
If you have a "complete" dash is will not be a problem
the 74 on squeeze type latches must be soemthing of a rareity these days
i broke mine a few years ago and couldnt get one anywhere
the only one i could get new was over $80
i got one out of a golf at the wreckers its the same overall just shorter had to grind down the striker plate to make it latch
Joel
:sandrine
Thanks Guys for your imput... :thumb
Yes we have the complete dash to put in..
(Jess's dash is no good in her 75 bug & we wanted to see
if we could put a wreaked 73's dash in it instead)
....just needed to know weather it would fit ok
thanks again
Judy
THANK U JUDY SO MUCH
your a life saviour
tahnk u for going to so much trouble :kiss
The panel in front of the dash where the defroster outlet is a bit different between the early and late. The early one has grilles cut in the metal
panel, the later ones have plastic outlets.
Thanks Steve :thumb
