I had this cut apart but carnt remember which way it goes ??:P
or this way ??? :jesus
cor! tricky one......:duh
any ideas ??
do you want to narrow it for a Looker? Or make it wider for an off-roader?
The two pieces with the shock towers go in the bin. You wont need those.
Cut torsion leaves to suit centre section and install trailing arms. Shim up with modified 'coke' cans if fit is sloppy.
Surely your not serious!
Cheers Dave
I would think the middle bit should go in the bin, and then it will be narrow enough to lower the front about 300mm. Must use valve springs in place
of shockers for decent suspension setup. I find Alfa Romeo valve springs fit just right.
Ring VINTAGE VW at CAMPSIE........Boris should be able to help you.
What about the accumen?
It will B negative hey
Positive 5 deg.
is that +5 or -5 degrees or inches
Well 'DAK To The Future' had +5 minus the 2 left over..................this would be the best option.
Picture 2
You are looking at the back of the central tube with the steering dampener on the left.
Move the piece on the left to the right and the piece on the right to the left and keep them both facing the way they are in the picture.
What is it Dave?
I think you best give Vintage a call they might be able to help you.
