Accelerator pedal pin keeps coming out
Purple Martin - April 26th, 2006 at 01:08 PM
The accelerator pedal pin keeps coming out of the hinge at the bottom of the pedal in my 1959 bug. What can I do to keep it in place?
[ Edited on 26-4-06 by Purple Martin ]
Yogie - April 26th, 2006 at 01:14 PM
You can buy a new kit for the later beetles but I am not sure about the early ones though. With mine, there is a wire that wraps around the pin and there is a little cutout that it sits in. This helps to keep it in but you can also crimp the brackets on the floorpan a bit to tighten around the pin once it is in position.
Good luck.
Yogie
vw54 - April 26th, 2006 at 01:27 PM
do u have the return spring on the pin its pushes the pedal into position
Doug Sweetman - April 26th, 2006 at 01:58 PM
yes, return spring is a neccessity, stops the accel pedal flopping back onto your foot....
1303Steve - April 26th, 2006 at 02:53 PM
Put a bolt through it.
