Hi everybody,
I have a trike with a type 3 auto, is it best to stick with the stock air cleaner or a better idea to put seperate air cleaners on both carbs?
If so what is best?
Any advice & info appreciated
Ken
Motorbike air filters (such as unifilter) are available to fit on each carb individually, just remove the rubber ring on the carby neck so that there
is some more area for the new filter to clamp onto.
Hope this helps.
[ Edited on 17/5/06 by *did* ]
Yeah use unifilter motorbike ones about $20 bucks each IIRC, put them on my notch and they work great, the carbs have a 50mm outside diameter, cheers Damo.
