just wondering what you guys would time a 1641 with a duel throat weber and a oo9 dizzy at?10` before top dead centre?
yep its all the same most of the time with a 009
you should time your engine so that max timing is like 30~32 deg at 2500+rpm. It does not matter what the static timing works out to be
how do i check that?cheers in advance!
http://www.geocities.com/aussiebug1970/
Check out this site, the guy that runs it often posts in here. But for the abridged version you will need a timing light with an advance
feature....or you can calculate where 32 deg is. Hold the phone..
print out this bad boy...use it as a template them mark 30 deg on your pully with a file or hacksaw blade. Then jusr put a standard timing light on
her and give her a rev. How easy is that
Cheers Stephen
thanks mate, very nice indeed!!!
