up to you really... maybe some thin insulating foam, then carpet using strong adhesive... personally my engine bit is covered by wood, then i've just
got a thick cushion which is part of the bed on top of it.
Not a very helpful pic... but yeah.... the thick foam helps keep the engine noise down aswell.
you should really be more careful with your whiteout when studying in ya bus mate!
curtains look hot
hahaha
I used carpet tape for the middle and stuck the edges down with contact cement looks fab///
Trevor//
