Does any one know where i can get my hands on an adjustable, widened ,king pin front beam? I need a wider track for my baja as the fenders are wider
than the wheels. Im running 15 x 6" or 7" up front and dont want to change the offset, or get wider wheels as the steering gets a little
heavy. The rubber strip/ flare things you see on 4x4"s look shite. Do they come complete with leaves or bare? I need to go at least another
2"- 4" wider and higher.
All help appreciated.
Try http://www.offroadracing.com.au
the offroad guys should be able to point you in the right direction, you might even be able to buy a complete set up off an old race car.
Good luck
Graham
