get it going
crazycritter - November 13th, 2006 at 12:55 AM
trying to get 2ltr twin carb kombi to fire after sitting 4 two yrs have put in 10ltrs fuel , electric pump is running but does not seem to be getting any juice up 2 carbies. Has spark at dizzy and motor winds over ok ,what yas reckon
xornge666x - November 13th, 2006 at 07:48 AM
spark at plugs?? put a little fuel down the carbs and that will let you know if it is spark or fuel. Not too much. If the elec pump has been sitting for a long time dry, depending on the make of pump some of them dont like it.
I had one that made noise but no fuel delivery it had sat for 3 years...
ancientbugger - November 13th, 2006 at 10:19 AM
If your pump's working but no fuel to your carbs either the inlet/outlet pipes on the pump are the wrong way round or both needle valves in the carbs are stuck or blocked.
[ Edited on 13-11-2006 by ancientbugger ]
