I need a key for one of our beetles, it didn't come with one, so where can I get one????
it's to fit into this
thanks, karina :bounce
take it to any locksmith and it can be done , or if you cant find one to do it post it to me in the gong and as i've been a locksmith for 14yrs and owned a crap load of vws i can cut a couple for you for a good price. If there is a code stamped on the casing a key can be cut from that aswell. if its a 60's bug the doors and ignition may be a different key ,the door handle will have the code stamped on it aswell (for the door only) 0428 427 986 klaus
thanks, Ill give the local locksmiths a go first but if no luck ill be giving you a shout!
karina
