Skip to content
Aussieveedubbers
Splined tool?
Share Share on Facebook Share on X Share on Reddit
Spellbound Seriously Crusin Dubber
151 posts · joined Nov 2005 ·
#566110
My Haynes Resto manual makes reference to a "splined tool" being the correct tool to remove driveshafts. What is it?? I have never heard of one before and those that I have asked have no idea either.
The book also says that I should NOT use a hex key as I may wear the splines on the inside of the bolts, as the tool won't fit correctly.
So to you guys that have removed CV's before.... do you guys use "splined tools" or if not...what do you use?
[ Edited on 21-1-2007 by Spellbound ]
barls Administrator Causer of Chaos and Mayhem
9,476 posts · joined Jun 2004 ·
#566124
i stead of being a hex its more like a star i think 12 point from memory, i use this splined tool but i can remember the size
the chaos project - click me
phil Seriously Crusin Dubber
128 posts · joined Mar 2005 ·
#566130
i think its a torx head bit ~8mm
get the right tool or replace with allen head bolts
#566139
phil wrote:i think its a torx head bit ~8mm
Cool...
Would I get one from Bunnings or the like??
mackaymanx Custom Title Time!
1,611 posts · joined Jan 2006 ·
#566141
It's a triple-square spline, I have a stahlwille with the size M8, Snap-on also list it as a M8. I think the correct name is XZN
Hazet XZN-8
[ Edited on 21-1-2007 by mackaymanx ]
1 attachment · Log in to view
Quote of the week
[IMG]https://www.vw-mplate.com/mplate2-18600.png[/IMG]
#566154
Excellent!!
Thanks heaps guys 👍
..great to have so much knowledge in one place.
Tim
dangerous 23 Windows of Awesome
5,901 posts · joined Jan 2005 ·
#566219
Take a sample bolt with you, mine is XZN-8 in Dowidat brand.
A 6mm AF allen key will do the job,but the correct tool will help prevent it chewing out.
Make sure you clean out all the gunk from inside the recess, or even the 12 point one wil 'skip' out.
If the hole has been butchered, an good 'vise grip' on the head may get you out of trouble.
westi wrote:That's mad Alan.
jnr356 Wolfsburg Wizard
603 posts · joined Jan 2004 ·
#566251
i've always called them multi splines sockets
make sure you pick the dirt & muck out of the bolt heads with a small screwdriver(even better if you can squirt some compressed air in there, watch your eyes!),then give the socket a tap with the hammer to make sure it's fully inserted.
best not to jerk your ratchet,better to use a smooth even action when undoing.
if you accidently round it off,tighten the two surrounding bolts and use vice grips or a large cold chisel and hammer to undo(watch them knuckles!)
wouldn't mind a dollar for every one of them suckers i've undone!
[ Edited on 22-1-07 by jnr356 ]
ctefeh Wolfsburg Wizard
479 posts · joined Apr 2005 ·
#566265
Hi,
Something else. Mine is a "bit" from a Minimax kit. You may be able to buy this 8mm trisquare "bit" seperately, either Minimax or whatever. All you need then is the appropriate driver (3/8 in my case) socket.
Ctefeh
Samblers Officially Full-On Dubber
236 posts · joined Apr 2005 ·
#566563
make sure that your CV bolts still have the splined heads - have you stuck your head under the car?
That tools is damn expensive and isnt used anywhere else so i'd get the old bolts off with an Allen head (24 of them - this took me 3 days once, dont ask!), then swop them for normal Allen head versions of correct quality.
If yuo cut the heads off with an angle grinder the shafts will just come off 😉
