problems with my motor (1916)
steve-89 - February 27th, 2007 at 08:27 PM
hey, been having some problems with my engine lately,
not sure wat seems to be the problem, but i have had several new exhausts put on it and either of the seem to make any difference, EG: when i got the
motor i bought it off the forum from a guy in QLD, he said it was fine and also said it was a big boar.
the motor its self has 40 delloretto"s and a lumpy cam,
Irecently went out and spent $330.00 on an empi extractor and muffler kit i got it home and fitted it, When i started it, the motor backfires and
sounds like the air cant get out,
Ialso bought an exhaust prior to that and got the same effect,
both systems are really noisy and sound really bad.
Is this something to do with my motor, like, is it out of tune or is it something to do with the exhaust pipe being to small in diameter,
can some one tell me wat the possibilitys are that it is something to do with my exhaust before i go out and blow big money on a custom one.
cheers steve
Craig Torrens - February 27th, 2007 at 08:34 PM
sounds more like you have a blocked pilet jet and fuel problems.
Bizarre - February 27th, 2007 at 08:38 PM
spark leads on the right plugs??
It doesnt sound like the exhaust
Worst case the motor would run without an exhaust - VERY loudly but "fairly" smoothly
[ Edited on 27-2-2007 by Bizarre ]
steve-89 - February 27th, 2007 at 10:21 PM
yeah the sparks and the leads are ok, it definetly got me puzzled.
craig- someone told me that it could be that ill have to check that out.
cheers boys
anything else it might be...
steve
lugnuts - February 28th, 2007 at 01:51 AM
Hey hows it goin,how long have you had this engine and was it running alright before and then not or has it always run like crap
lugnuts - February 28th, 2007 at 01:55 AM
Originally
posted by steve-89
cheers steve
STOP,please dont spend anymore money!!!!!!!:P
newoldmanx - February 28th, 2007 at 07:49 AM
didnt drop a washer or a nut into a port when you were taking the old system off did ya???
did you do a comp test b4/when you got the donk?
how long did the car you put the motor in sit for before the transplant??? could be stale/ dirty fuel
id start from scratch plugs, points, timing,rocker clearance, drain fuel bowls, clean and check dizzy cap, check carb linkage compression,etc all
cheap and will only benefit motor anyway
VWCOOL - February 28th, 2007 at 08:08 AM
FAST - fuel, air, spark, timing (valve and ignition)
If it has all these in the correct sequence, it will work!
newoldmanx - February 28th, 2007 at 09:21 AM
Originally
posted by VWCOOL
like he said ----i would add one more F.A.S.T.Compression:thumb
steve-89 - February 28th, 2007 at 10:31 AM
Lugnuts: what do you mean by that...?
thanks guys ill get that checked out asap.
steve
VWCOOL - February 28th, 2007 at 10:33 AM
Originally
posted by newoldmanx
posted by VWCOOL
Yeah, maybe better said : FACT!
newoldmanx - February 28th, 2007 at 11:46 AM
Originally
posted by VWCOOL
posted by VWCOOL
lets say F.A.C.T.S ????????:thumb
koolkarmakombi - February 28th, 2007 at 05:47 PM
has it ever ran well in your hands?
steve-89 - February 28th, 2007 at 06:09 PM
KKK: yeah when i had a bigger exhaust on it
steve
Joel - February 28th, 2007 at 06:47 PM
sounds like it needs rejetting
free flowing exhausts often require fiddling with the jet sizes
especially the idle jets
-Joel
VWCOOL - February 28th, 2007 at 07:11 PM
Originally
posted by VWCOOL
posted by VWCOOL
:thumb:thumb:
we got it aaaalllll covered now!
newoldmanx - February 28th, 2007 at 08:30 PM
Originally
posted by VWCOOL
posted by VWCOOL
posted by VWCOOL
| :thumb:thumb:
something tell me you play a lot of scrabble
koolkarmakombi - March 1st, 2007 at 08:12 AM
Acronyms -R- Us
Originally
posted by VWCOOL
posted by VWCOOL
posted by VWCOOL
| :thumb:thumb:
steve-89 - March 2nd, 2007 at 02:38 PM
cheers for that guys..
steve
steve-89 - March 4th, 2007 at 12:55 AM
well after all problems i think the major one is now sorted..
this is my newly aquired exhaust. sweet hey....
well all that needs to be done is the jetting and the tuning.
thanks for everyones help.
steve
Gracey - March 4th, 2007 at 03:17 PM
Got anymore photo's of that exhaust, like looking up at it from underneath?
steve-89 - March 14th, 2007 at 04:18 PM
steve-89 - March 14th, 2007 at 04:21 PM
j pipes. and 4 into 2 connection. need any more just ask....
steve
Gracey - March 14th, 2007 at 10:03 PM
Thanks for the pics. Interesting exhaust system.
Let us know how it performs.
