Replacing Clutch
Roukis - May 8th, 2003 at 12:17 PM
How much does it roughly cost to replace a clutch in a Beetle.
If I were to do it myself how difficult is it to do assuming I know how to remove the motor.
J&SBlue - May 8th, 2003 at 01:12 PM
If you know how to get the motor out then you should have no troubles replacing the clutch.
Sorry, no idea how much it would cost to get it done though.
[Edited on 8-5-2003 by J&SBlue]
Bizarre - May 8th, 2003 at 01:33 PM
Clutch kits are $280-ish for standard
You have a 1776?
Might want to consider HD @ $400-ish
Remove and replace? couple hours? $100 - 150
You have Porsche shroud and duals...... might complicate things? Duals have to come off before the motor comes out - does you shroud have to come off?
Roukis - May 8th, 2003 at 04:29 PM
Shroud looks like it can stay on since the bottom perimeter of the shroud is below the engine bay seal.
While it is out I wanted to fix the leak from the back of the motor. Between engine and gearbox. Is this a common leaky area that can be replaced without dissambling the motor. I have a Berg sump. May be the gasket between the Berg sump (if there is one) and the engine has perished.
