I've just converted my 65 beetle from 6v to 12v and i am wondering which battery is used....a 6v battery or 12v battery?
None of the articles i've read say anything about running a 12v battery
sean
12volt :thumb
a 12 volt conversion is just that.. converting everything to 12v!
12v battery included
(and you may run voltage droppers for some items that cannot be converted)
[ Edited on 14/4/07 by *did* ]
Thanks for the replies
the only thing i didn't convert is the starter and solenoid as the 12v solenoid won't fit my starter....can i add a voltage dropper to this?
i just use the 6 volt starter but then again my one is not a daily driver
thanks again
the thing is when i tried the 12v battery the starter didn't seem to like it but when i tried the 6v battery it started straight up
i'm going to try the 12v again tomorrow after a charge tonight and see how it goes
i got a 58 with 12v... and a 6v starter, spins up and kicks over every time, just don't hold it too long... if having starting probs give the starter
a rest every now and again..
when u say "the starter didnt seem to like it" what to you mean exactly?.
Starter should work fine on 12 volts. I had one on a daily for 5 years and had no problems,just spun faster !!
Ok
12v battery working fine now
.....don't know what was going on
with the starter
now i gotta find out why both front blinkers aren't working.....rear ones working fine
the joys of working with electrics
