Educated gentlemen,
My 73 S bug (3 bolt struts) has a very annoying vibration in the steering that is real bad between 70 and 80 kmh, then gets better but is still
noticable up to 110kmh.
I have second hand empi 8 spokes, with second hand 195/60/15's on the front.
I have replaced the following already;
Ball joints
Discs (were warped and thin anyway)
Strut inserts
Steering Damper
Brake pads
I have had a reputable VW mechanic look at the front end up on a hoist, and he checked all the tie rod ends, and said they were fine. The previous
owner replaced the control arm bushes.
I have had the wheels balanced off the car, and the wheel alignment is set at 1.5mm toe in and 0 camber angle.
I know that the sway bar bushes need replacing, and that is probably next on the list.
The steering box has very little play at straight ahead, but about an inch and a quarter at lock.
Any suggestions about what to do next ?
Balance the wheels on the car ?
Anybody else have this problem ?
Any one cured this problem ? What did you do ?
Look forward to ALL your comments
Thanks once again ladies and gents.:kiss
Most super-bugs wobble with larger than std wheels unless all bushes are replaced with poly ones, strut brace to stop the body flex and good tyres.:puke
Have a look at the American web site:
http://www.superbeetlesonly.com[/url]
A very informative site.
Regards,
Mark:thumb
i had similar problems with both my supers. Ended up new inserts , bushes, and any aballjoints that needed doing and its now perfect.
Weld on a Torsion bar bulk head then you can have some real enjoyment with a good handling car.
sounds like wheel balance to me... but you say thats been done.
Are the wheel bearings noisey or loose ???
Sorry guys, but I dont buy the theory that wider than standard tyres cause it. Its bullshit - the tyres are only 30mm wider than stock, so thats only
another 15mm offset load on the suspension. Which will cause suspect components to show up quicker I agree.
The shudder was just as bad with standard rims and tyres
Wheel bearings are fine - re packed them yesterday.
Was just curious if it happened to be one component more often than another.
I agree with Dave, "weld a framehead to suit a Torsion bar ", with disc brakes and now you have a great handling car. I've just done
that and there's no comparison.
But I suppose there must be an answer, without being 'that' radical. Keep the 'ideas' comming.
Regards,
Mark:thumb
we had the same trouble and it was cured completly by replacing all the rubbers with poly bushes do them all -- the inners and both sway bar lots and it will be great be shure to get a good alignment when you have finished and check the lower ball joints carefully:thumb
yeah
it is not the wheels
Blue 1 and 2 both ran 6" 195's up front and steady as a rock.
Years ago Blue suffered badly with the "shimmies" and the main culprit was the steering box.
I reckon the best answer would be replacing all bushes in one hit.
Also check the steering universal. I ahve had BIG trouble with them.
I have also read about them being sensitive to tyre rotation. I would definetley get them balanced on the car if that is a last resort.
How old is the box?
You got a spare you could try?
What about the pittman arm on the other side?
DEFINETLEY read the tech articles in http://www.superbeetlesonly.com
Post there - as you do. James and Ryan are VERY informative when it comes to supers
TORSION BARS :puke heh heh heh (joke to everyone EXCEPT you know who :kiss)
Balance the wheels on the car.
I'm not sure if one of the above links was to this post on superbeetles.com, but one of the guys there spun his wheels up with the car on jack
stands and just altered where they sat on the hub each time until the car no longer vibrated with the wheels at speed. (he'd had his wheels
balanced off the car and was still having trouble before this).
I fluked it one day by bolting up my wheels a different way and suddenly realised my shimmy had gone. My wheels had been balanced off the car, but
supers are really prone to front wheel balance. Once this is done put a paint mark on the hub and one on the wheel or a mark on the hub where the
valve needs to line up.
This is what I'd be looking at especially since you mention you've checked every thing else.
Oh a few more things to check, since you mention 2nd hand tyre and wheels- make sure your wheels are straight, a 4WD freind of mine reckoned those
wheel balance machines won't show if your wheel is bent, so check this and make sure your tyres don't have any major bruises etc on them,
this can also effect the balance.
Jeremy
I dont buy the bigger wheel therory either, since I fixed my car with poly bushes and an adjustable caster front sway bar I have used 15x7 wheels,
16x7 & 17x8 with no shudder. In the old days my car was very easliy upset by a poor wheel balance.
I think we all consider Porsches a performance beetle, well why dont they still use a beam front end? :bounce
1302Steve
They carnt afford to build a torsion bar anymore...
Barry thats discusting :puke:puke:puke
I suppose I should take out the IRS and put a swing axle in the rear too eh ?
Sorry to get cranky guys, but I completely disagree with your ideas about torsion bar front ends handling better.
I've owned a 67 with 1800 type 4 in it, went pretty well, but the 73 handles a level above, and thats even without the front end properly sorted.
Turns in sharper, holds its line better and is nowhere near as tail happy (obviously, this is the IRS at work).
Sure torsion bar front ends are easier to maintain, stronger and last longer, less sensitive to wear and easier to understand. But there is no where
near as much scope for set up as struts, and they weight just a tad more I believe....
Anyways, enough of the 'weld a tosion bar to it'. I know you are only joking, but its monday morning and I'm cranky so leave me alone
Pitman arm seemed fine - there was no real play in it. I'm pretty sure all the play in the steering is in the box - but I dont know the condition
of the uni joints, so I will have to check them too.
Looks like next on the list is nolathane sway bar bushes and an on car balance.
Thanks for all your input, constructive and otherwise
Please excuse my rant :jesus
