Draining a T3
Bizarre - May 13th, 2007 at 06:47 PM
as it says - how do you drain the fluid from a T3
Is there a drain plug or do you undo one of the hoses somewhere??
Barry
Menangler - May 13th, 2007 at 08:18 PM
What fluid?
engine oil, auto fluid, geabox oil, brake fluid. power steer fluid or coolant.
Coolant I suspect, undo one of the hoses.
[ Edited on 13-5-2007 by Menangler ]
Bizarre - May 13th, 2007 at 09:07 PM
ummmm....yeah..... coolant
So you would most likely undo one of the hoses near the spare wheel where the rubber hose joins the solid tube
