What can I spray the EJ20 engine with that I am in the process of fitting to the Manx SR, and then pressure wash it off?
What I need is something that won't damage anything but will brighten things up a bit, before I attach the eletronics.
I'm not going to pull it apart and polish it, or walnut shell blast it, I just want it to look nice and clean and a bit shiny, with a minimum or
oxidation on it.
I've been told that CT18 (or is that CT21,?) will do it.
Am I right to remember that the Myth Busters showed that Coca Cola will do that sort of job?
cheap degreaser. I cleaned mine the other night before starting to pull it out and it was pretty good. they come up pretty good with a simple clean anyway.
yeah what pete said ,i just buy the cheapest degreaser i can find and it works a treat
