I picked up a gearbox for my Type 3 the other day, just wanted to verify what its out of.
The first three numbers stamped on it are 113 and its an IRS box.
beetle or type 3
Oh cool.. so hopefully it is what he says it is! (Type 3)
Just wasn't sure when i looked up the number in the idiot book and it told me it was a '73 beetle box *shrug*
you wont know untill you open it up and check the ratios
Look on the lower area where there is a STAMPED number (rather than cast).
There will be a letter and number code stamped on a flat area, kind of like you engine number is stamped.
It is true that if someone has been inside it, it could have anything in there,
but if it is AT.... it will be 3.875, AH...(bug) or D..(type3) will be 4.125.
http://www.midsouthvw.com/TechTips/tech_tip_TransaxleCode.htm
Thanks guys.. as long as its type 3 ratios or higher ![]()
