sealant on oil pump gasket
homer - July 7th, 2007 at 06:43 PM
i put gasket cement on the gasket between the oil pump and the engine cases and then read in a manual not to use it. will this be a problem? the manual also said to use new nuts on the cover. is this also correct?
vwrallycar - July 7th, 2007 at 07:09 PM
i use the permatex gasket sealant on mine when i assemble them, so there will be no harm.
as for the nuts, if you reuse the old ones, once they are torqued correctly they wont pose a problem, but for the sake of a couple of dollars and peace of mind, use new nyloc nuts.
other people/manuals will have different views, just comes down to your own choice
homer - July 7th, 2007 at 07:20 PM
do you use the normal nyloc nuts from auto suppliers, hardware stores etc?
VWCOOL - July 8th, 2007 at 03:55 PM
gasket sealer is okay as long as it is oil 'soluble' like the brown Permatex stuff... but not silicon
How much heat do Nyloc nuts cope with?
homer - July 8th, 2007 at 04:34 PM
i dont know how much heat a nyloc nut will take. can you buy special nuts for this purpose? i may have to take the pulley off and change them.
vwrallycar - July 8th, 2007 at 05:32 PM
nyloc nuts are fine for use on the engine, but not on the exhaust. you can use the ones from the local nut and bolt place
yeah use the brown permatex.
homer - July 8th, 2007 at 06:31 PM
thanks for the replies guys
