real tricky question.
twoguns - May 16th, 2003 at 05:51 PM
i think my splits protesting and i need some help.
the problem is that when i get over 100-110 the indicators no longer work. they might flash once but generally not at all. when i slow back down to about seventy they start working again and when i am travelling around town they are fine. but once the needle passes 70miles they stop. does anyone have any ideas? is really starting to frustrate...
manxed69 - May 16th, 2003 at 10:07 PM
Is it a regulator problem? I would check the voltage at different rpm to see if its in the 12 -14 volt range.
Next I would change the flasher relay.
fish - May 16th, 2003 at 11:05 PM
yeah its a regulator problem. i had the the speakers fade out when i hit 60 klm and then come back on at 40klm. talked to my auto elec and new reg and is ok. when you commin up the coast. love to see your bus.!!!!
twoguns - May 18th, 2003 at 02:24 PM
thanks guys. will get that checked... after i replace the exhaust and extractors. blew a few holes in them coming back from up north in the rain. didn't really notice it over the music, just thought the sub was a little off. did see a little drop going up hills. found out when i went to fill up and had turned the music down so as not to disturb the others at the station. she's almost as loud as my harley at teh moment.
fish the closest im getting to north at the moment will be nambucca....
