Fuel filters
njg02 - October 4th, 2007 at 03:53 PM
Afternoon!
I have two fuel filters on my type 3. One above the gearbox(good spot), teh other on the outlet of the fuel pump before the tee peice to each carb. I don't think that I need this second one. What do you think?
Neil
vw54 - October 4th, 2007 at 04:07 PM
one under the gearbox is enough just remember to change it when required
njg02 - October 4th, 2007 at 04:12 PM
Thanks Dave, just what I thought. It looks fairly new ~2000mi so I'll keep it as a spare. Now to do all the fuel lines.
Neil
vw54 - October 4th, 2007 at 05:05 PM
i would use a small clamp on each of the fule lines out of the pump to the carby
and use some tie wire to hold it in position as the brass outlet pipes some times fly off
njg02 - October 4th, 2007 at 05:33 PM
There are clamps on all ends and leaving the filter out after the pump will give me two less spots where losing hoses could happen.
Shifter bushing is next. And Compufire.
Neil
