removing ignition switch from the barrel on a 68 bug
happyoldhippy - October 13th, 2007 at 05:26 PM
hey, I'm frustrated!.. gotta replace the ignition switch on my 68 beetle... got the housing out... got the barrel out (after FINALLY finding the little hole where you stick a piece of wire in to release the spring thing)
my question:
what the dickens holds the ignition plug thing in the back of the housing?? I can see that there is a little pin with splines on it holding the plate in the middle, but the ignition switch seems to be really solid in there! what am I missing?? I got the replacement switch all ready to go, but... :duh
Bizarre - October 13th, 2007 at 06:12 PM
G'day Happy
Have a read here and see if it helps
http://www.vw-resource.com/ignition_switch_replacement.html#ignition
1968 thru 1971 Models -
Insert the key into the lock cylinder and turn the key slightly, then pull the cylinder out until the retaining spring on the top or side is visible in the opening.
Using a nail or a piece of steel wire inserted through the hole in the lock assembly’s housing, depress the retaining spring on the lock cylinder while pulling the lock cylinder out.
Remove the lock cylinder by turning the key all the way to the 'start' position and pulling the lock cylinder out of the housing.
Barry
Joel - October 13th, 2007 at 07:22 PM
from memory theres a tiny little blade screw in the side of it
think u get at it from below where the wiring comes out
xornge666x - October 13th, 2007 at 11:44 PM
yep, little grub/set screw in the side of the barrel that holds the ignition blocl (elec switch part) in.
If you have the new one, you should be able to see where the screw will be on the old one.
Rota_Motor - October 19th, 2007 at 07:19 PM
silly question, where do I find a new ignition switch to suit a 68 beetle, and do switches from other models fit, and do the wires plug in anywhere, or do I need to cut and splice the new switch in??
oh yeah, this is because Danielles ignition switch self destructed when I was in there trying to figure out the horn wiring.
68AutoBug - October 19th, 2007 at 08:30 PM
I've never seen a new electrical part of the ignition switch for a 1968 beete.
as you know they habe the wires soldered onto the switch...
I really don't know whether a switch from a 1971 super would fit...
maybe a complete assembly from later model beetle will fit
I have a spare for My 68 beetle but its only one I've ever come across, so I bought it for a spare..
I don't know what holds it all together on a later model
with push on connectors.
