any kits avail for adjusting camber on a type 3.
Brian
If your talking about the front end you have to remove the arms and bend them in a press no kits
thanks dave
I thought that the lower ball joints had a camber adjustment.
Ball joint beetles have camber/caster adjusters...
type 3s had splines in the front end to adjust height...
they would have to have something to adjust the camber/caster....
the yellow one is original VW
gold one is aftermarket.. more adjustment..
1500 beetle - same as 1976 beetle...
I no longer have any type 3 manuals
so I can't really be sure....
yeah they do but if you need more then the arms have to be bent
If you only want stock it would be a good idea to pull them apart and lub up so its easier for the soft hands of the wheel aligner dont want them
skinning there knuckles
