Has anyone done this on an early beetle before? Just interested to know which way they mounted (if a bracket was used or not) and possible
measurements on position.
yeah talk with Mike at Vintage 9789-1777
he had them on his peach 58 beetle years ago n work well
Aircooled.net sell them
Cheers lads. If anyone has a photo of the mounting spot that would be tops, assume its pretty basic, but photos are always nice. I'll talk to Mike
They use the stock mounting points.
Steve, i don't think there were any mounting points on a 58? Is this correct? I think they used a latch to keep it open once pulled up...
yep no stock mounting points on the 58
thats the hard part working out the mount point with the strut that you use
Yeppo, took some measurements of the shell outside vintage veedub. Will make my own brackets and play with positioning. I've got one of the standard
kits so the struts are the right length. Should be a ball
