how hard is it to replace genny bearings?
Anthiron - April 16th, 2008 at 01:36 PM
well the title says it all.
how hard is it to replace worn bearings in a generator? type 1 if that matters.
Nicko
OZ Towdster - April 16th, 2008 at 04:31 PM
Not that hard and we have the bearings in stock @ Custom Vee Dub 33564356
Anthiron - April 16th, 2008 at 04:44 PM
hi andrew
do i just unbolt the fan assembly and it all comes apart? will i need a bearing puller?
OZ Towdster - April 16th, 2008 at 05:11 PM
you won't require a puller i believe , but it has been a while since i looked at a genny nick
Anthiron - April 16th, 2008 at 05:36 PM
ok well ill pull it apart tonite and see what it looks like. thanks for the tips
type3lover - April 16th, 2008 at 10:28 PM
From memory you won't need a puller and the bearings are very common. Cost less than $10 each when I did mine.
