As the title suggests.... Is there anything I can do to improve my CB 044 Wedgie?....
Some of you may know that I'm building a long awaited 2276 EFI/Intercooled/Turbo engine and I'm hoping to actually start the build this winter...
So before I dig in is there any room for the layman to make improvements on these heads?
Muffin Man? Any ideas oh great Sage from the Nor East? Anyone?
Put a shim under the springs to stop chaffing.
You may like to dowel the manifolds if yours are loose from CB.
Remove sharp edges from the chambers.
Use a dummy valve to protect the seats from the rotary burr. (Raymond)
Perhaps check the valve job is to suit your valve size.
Some are 44 valve and have a seat to suit a 42.
http://forums.aussieveedubbers.com/viewtopic.php?tid=38974&page=4
Some other related info from Alan's upgrade.
Cheers Dave..... Will dig those babies out and have a gander at the seats.... That is a little odd that some 44 valves had 42 seats!!?? And thanks for the other tips.....
